| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 31 | I just installed a 72, 12 bolt in my 61 or should I say tried.The width of the perches for the swing arm are about 6 to 8 inch narrower than mine. Everbody I talked to said it was a direct bolt in,NOT. They will hit on the frame when travel goes up.I will have to weld new brackets so everything lines up right.I didn't know if anyone had heard of this.Also causes the springs and shocks to be misaligned. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 60-62 is a whole diff ball game, not the same as 63-72 | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I had a 66, when I needed to switch it ,I tried a 61, NO GO, they do not interchange.I ended up getting one from a 71.These were all 12 bolts, my pinion shaft had snapped. Lothar | | |
