6 members (JW51, KEVINSKI, Joe H, WingWright, 3800GUY, Gdads51), 121 guests, and 1 robot.
Topics128,110
Posts1,056,255
Members48,437
#341804 11/26/2007 8:36 PM
I just installed a 72, 12 bolt in my 61 or should I say tried.The width of the perches for the swing arm are about 6 to 8 inch narrower than mine. Everbody I talked to said it was a direct bolt in,NOT. They will hit on the frame when travel goes up.I will have to weld new brackets so everything lines up right.I didn't know if anyone had heard of this.Also causes the springs and shocks to be misaligned.
My 1961 Chevy Pickup Truck
In the GalleryMy Webshots Shoebox
60-62 is a whole diff ball game, not the same as 63-72
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I had a 66, when I needed to switch it ,I tried a 61, NO GO, they do not interchange.I ended up getting one from a 71.These were all 12 bolts, my pinion shaft had snapped.
Lothar
