1 members (2-Ton), 92 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
Question? Has anyone swapped out the babbet rods to the machined insert bearing type rods in their 216? If so, what connecting rod to crankshaft clearance did you establish? My guess-ta-mation is .001 minimum to .0015 maximum, am I guessing right?
Best Regards
Will
I had mine machined to take inserts and they worked out very nicely. I think those numbers that you mentioned are good guide lines.
1951 1 Ton Completed
