5 members (G508, mick53, Peggy M, TIM ZINDLER, 1 invisible), 101 guests, and 5 robots.
Topics128,269
Posts1,058,403
Members48,485
#341547 11/26/2007 12:27 AM
Apprentice
Apprentice
just wondering if any of you have done this or if its possible,i have a 216 tranny 3spd no overdrive that was in the truck when i bought it and was wondering if i go with a full pressurized oil 235 from a latter truck would thier be any prombloms, i want to be able to go 65 70 on the highway with new gearing in the back and if this is possible what gears would i need if i ran around 30" tires
thanks
As for gears ratio I would use 3.42 or 3.54/3.55s. Thats the lowest ratio I would go with no overdrive and with 30 inch tires. I knew someone that used 3.40/3.42s with their 235 and loved it. Saved a bunch of gas. Its the ratio I would choose unless I was going to do some towing. It can go down the road at hwy speeds without screaming. Their truck used to have 4.11s which was too low. They had no overdrive either. With 32 or 33's you can use 3.55/3.73 gears. I am not sure about the trans but I believe it will work for you. Bell housing may be different but should interchange with no problems. Someone else here I am sure will know on that. Henry
The 235 should mount right up .However, you will need the front engine plate from the 216 or you'll have to drill 2 mounting holes in the 235 front plate to mount the 235 in your truck.
Drew
