| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 36 New Guy | | New Guy Joined: Aug 2007 Posts: 36 | My Brother-in-law has a 69 c-10 chevy LWB that he has owned since 1970. He parke the truck a couple of years ago and the drivers side rear went flat. Will not hold air so he has tried to remove the wheel to get the flat repaired. However, the wheel is apparantly rusted to the hub. He has tried saturating with WD-40 and has even bumped and tried lifting the wheel with his front end loader but wheel wont' budge. Any ideas how he might remove the wheel?
Robert | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Lay down & hit it from behind with a big hammer. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With the lug nuts loose drive around the parking lot slowly with tight turns. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | PB Blaster available at your local Auto Parts Store. Then smack the wheel a few times with a hammer. Go to lunch, should be loose by the time you are done eating. If not, a 2x4 behind the wheel for leverage.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I usually give it the sledge hammer treatment. They sure can be stubborn sometimes, but I've never let a rusty wheel get the better of me. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | With the lug nuts loose drive around the parking lot slowly with tight turns. This is the best way I have found to get them loose OR use some heat around the center may also pop it loose. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No heat, bad for the seals abd bearings. The sledge trick works well, but can damage the rim if you get carried away. I use a 6' prybar at work to pop off stubborn wheels, usually don't even need any penetrant. When you get it off, put a light coating of anti-seize on the hub, where the wheel seats and on the center hole of the wheel. Just a light coat, doesn't need to be much. That will prevent seizing in the future.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Last time that happened to me, I took off the lug nuts and tapped the bolts inward as far as they'd go. Be real careful. Just my 2 cents. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Here's another vote for the loosened lugnuts and tight turns approach. I've used that method a few times and it's a lot lets work than the others. Of course, it works best if the truck is actually running.... | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Bill whenever I used heat it took very little heat to pop the rim or brake drum loose & considering it has sat since 1970 I would pull the bearings out anyway & replace or repack them. AND if you have heated the drum/wheel up enough to melt a seal then you have more problems then a stuck rim...Joe | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can see using heat as long as you keep it low. I was more thinking about cooking the grease in the hub. I do agree, especially since it's been sitting, a repack/new bearings/seals, along with a complete brake inspection, is definetly reccommended. Also, when I hear the words "use some heat", I get images of some of my co-workers who tend to get carried away with it  . Same guy likes to use the whole can of PB on one job, too. Thinks more is better.
