1 members (baldeagle),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 14 New Guy | | New Guy Joined: Sep 2006 Posts: 14 | I made a very stupid mistake and now I need help. I have been restoring a 53 GMC 3100 that I recently purchased. I ordered a master cylinder rebuild kit and disassembled the master cylinder before I recieved the new kit. I assumed the kit would come with a new spring so I threw away my old master cylinder spring. Any leads on where I can pick one up? Will local hardware stores carry ones that will work. Man, I feel stupid. I should have known better.
Pletch 65 Chevy fleetside 69 Datsun Roadster (sold) 68 Chevy long bed step side (sold) 53 GMC 3100 (sold)
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | You will need a spring from another master cylinder. The hardware store springs probably will not work right with the pressure valve at the end of the master cylinder. The spring needs to fit just right on the valve to keep a small amount of pressure on the wheel cylinders. Some of the other stove bolters should have extra parts laying around. Before you spend a lot of time looking for parts I would hone and measure your current master cylinder and see if it's worth rebuilding. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Pletch, I have my old rusty master cylinder from my 1950 Chevy 3100.If it works for you, you can have the whole thing or I'll dismantle it and ship you the spring. Let me know.
Drew
| | | | | Joined: Sep 2006 Posts: 14 New Guy | | New Guy Joined: Sep 2006 Posts: 14 | which ever is easier for you. Let me know how much you need for shipping.
Thank you
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I pulled the cylinder a part so I'll send the spring with the rest of the internals. Click on my name and send a PM(Private Message) with your address. It's light, so I'll send it first class.No charge.
Drew
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Pletch,,Just figure it as a lesson learned. Dont toss anything until youre completely done with the project. Even then,,you may want to save the parts so you can help fellow Stovebolters that make the same mistake. We've all "been there,done that" Good man,Drew!!! Marty | | | | | Joined: Sep 2006 Posts: 14 New Guy | | New Guy Joined: Sep 2006 Posts: 14 | the spring arrived last week and it worked perfect!!!!
Thank you for your Help Drew!!!
