3 members (Otto Skorzeny, MNSmith, tclederman), 73 guests, and 1 robot.
Topics128,052
Posts1,055,718
#340355 11/23/2007 12:44 AM
Will the oxygen sensor run off of just one header, or do I need to install another o2 sensor. If so do I just splice the wires for both sides together ? Thanks in advance
Alot will depend on what engine and computer engine manegement system you'll be using. Some only require 1, in which case only the 1 will be needed. But some (especially newer systems) will use separate sensors for both sides, or even before and after sensors (4 total) on the cat(s) to monitor the system. make sure of what the system you're using requires.
Bill Burmeister
I have seen guys use a crossover & put the 02 sensor there
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
That would work, but it might take longer for the sensor to come up to temperature where it will read accuratly.
Bill Burmeister
thanks. I will use one, that is what the system is set up for.
1 Offline
Tim,
I installed a GM throttle body EFI on my 51 and on my 86 and have headers on both of them, I only installed one also and put the O2 sensor on the header collector, worked out sweet and Ive had no problems what so ever
Check it out http://rides.webshots.com/photo/2078676030100410726AVAMhJ
Good luck bud
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
