0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | As long as we are talking about horns, I have been working on a trumpet style horn for the 52. Justin Rubsam sent me some capacitors to experiment with, as the original was shot. I thought I would clean up the internals befor trying the caps. It turns out that what I thought was a paper diaphram or resonator is metal. The paper is what appears to be a gasket. Before I just scrape it off to clean the metal resonator, would anybody have a suggestion on a replacement for the paper gasket? It appears to be a thick, waterproof paper. Something on the order of heavy brown paper. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I used thin gasket material on mine.
