2 members (78buckshot, NJC), 98 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
Apprentice
Apprentice
i just removed the engine and transmission. i also removed the fenders and radiator off of my 52 gmc one ton. Next, i want to remove the cab. how do i remove the steering wheel so i can lift the cab off..
You need to pop the horn button off, remove the big nut and the horn mechanism and then use a steering wheel puller with the correct bolts. I would suggest removing your steeing box too before removing the cab.
1951 1 Ton Completed
Apprentice
Apprentice
thanks for the reply. do you mind sending me pics of your one ton. are your finished with it or is it a work in progress
Here is a link to my webshots:
http://community.webshots.com/user/fnixon1
I have to post new pictures because it now has a professional finish. It is on the road now but it is resting for the snow season!
Fred
