i just removed the engine and transmission. i also removed the fenders and radiator off of my 52 gmc one ton. Next, i want to remove the cab. how do i remove the steering wheel so i can lift the cab off..
You need to pop the horn button off, remove the big nut and the horn mechanism and then use a steering wheel puller with the correct bolts. I would suggest removing your steeing box too before removing the cab.
