| | | Forums66 Topics128,081 Posts1,056,319 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 20 Apprentice | | Apprentice Joined: Oct 2007 Posts: 20 | i just removed the engine and transmission. i also removed the fenders and radiator off of my 52 gmc one ton. Next, i want to remove the cab. how do i remove the steering wheel so i can lift the cab off.. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You need to pop the horn button off, remove the big nut and the horn mechanism and then use a steering wheel puller with the correct bolts. I would suggest removing your steeing box too before removing the cab. | | | | | Joined: Oct 2007 Posts: 20 Apprentice | | Apprentice Joined: Oct 2007 Posts: 20 | thanks for the reply. do you mind sending me pics of your one ton. are your finished with it or is it a work in progress | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is a link to my webshots: http://community.webshots.com/user/fnixon1I have to post new pictures because it now has a professional finish. It is on the road now but it is resting for the snow season! Fred | | |
