1 members (Millenimech), 118 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
I need to install both emergency cables on my 62 1/2 ton Chevy pickup-Short wide bed. Anyone have any basic instructions that will help? I presently have the broken cable wired together but don't know how long the wire will hold!!!Thanks in advance for help.
Green Machine
You need to pick up a shop manual for this truck will make life much easier. There may be some info via online manuals check the tips etc on this site. Also you should be able to find another correct cable per an ad in these classifieds.
1946 1/2-Ton Chevy
Ed,,if you are talking the 2 rear cables it,s just remove old and install new,,they are clipped into rear plate with spring holding cable in shoe arm just compress spring with side cutter and remove from arm do same with new cable when installing with some luck you can do it without removing shoe from backing...doc
