| | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | I need to install both emergency cables on my 62 1/2 ton Chevy pickup-Short wide bed. Anyone have any basic instructions that will help? I presently have the broken cable wired together but don't know how long the wire will hold!!!Thanks in advance for help.
Green Machine
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You need to pick up a shop manual for this truck will make life much easier. There may be some info via online manuals check the tips etc on this site. Also you should be able to find another correct cable per an ad in these classifieds. | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Ed,,if you are talking the 2 rear cables it,s just remove old and install new,,they are clipped into rear plate with spring holding cable in shoe arm just compress spring with side cutter and remove from arm do same with new cable when installing with some luck you can do it without removing shoe from backing...doc | | |
