3 members (Otto Skorzeny, UtahYork, tclederman), 109 guests, and 3 robots.
Topics128,087
Posts1,056,377
Members48,442
#336501 11/12/2007 11:19 PM
All & Any,
Does the late model blazer gas tanks fit between the frame rails of a 60-62 like they do for 63-66? If not, is there an aftermarket tank that will work or another late model vehicle that would work?
Thanks all....
1961 Chevy C10 Stepside
On my web site
I don't know which Blazer tank you're talking about. The one I have came from Coleman's Military Surplus. They were an 80s Diesel tank. However they have no more of these, probably because they sold for 25.00. That tank will fit the 3100 AD (not the 3600). I don't know if it will fit your application.
~Jim
This is one of those things I always try to warn 60-62 owners about. I've taken measurements under my frame and haven't found any commercially available that fit where and how I want. That's not to say there isn't anything out there, I just haven't found it yet. There are custom fab shops that can build to your specs - How much $ you got?
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
bigmacdaddy is right, however after you've bought a few tanks that don't fit, like me, then that custom $ tank is not so expensive. I have found you must be very careful when measuring. On mine the frame rails were wide enough but I didn't notice the spring shackle nuts were protruding just enough that my Blazer won't work.
Big Chevy I'm suprised your tank wouldn't work. I put one in mine without any problems.
Robert C.
I'm a Genius in the making.
1950 3600
You probably did not replace your springs. I replaced mine with a TCI kit which puts the spring shackles directly under the frame rail.
~Jim
Hmmmm....I've got a '62 Suburban, with a between-rails tank that works with the spare tire carrier. (factory application).
I'd like to put a new tank in there, but haven't found that anyone makes them yet.
However, the '57 Chevy station wagon tank I have looks like it'll be a close match, except the cut-out for the tire is on the top, rather than bottom half of the tank (as the spare tire well in the wagon was in the floor, not under the floor).
It wouldn't be a direct bolt-in, but it's a starting point.
A '55-'57 Chevy car tank might also work...they're fairly compact. and the filler tubes are also available.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
hi, theres a two opptions 69-72 blazer tank that bolts right to the frame if you have coil springs and theres a alum. tank that made just for you truck tuckersparts.com sells them.
Big Chevy, did you replace them to run bigger tires?
Robert C.
1950 3600
Yes, I replaced them so if I decide to swap to a wider tire I would have the option. That was my secondary reason; my first reason was to soften the ride.
~Jim
Thanks for the feedback. I will probably opt for the aftermarket aluminum tank option if I still have funds available ohwell
On my web site
i was looking to do an under bed replacement on a 65 chevy short step half ton. any advise?? out of all the aftermarket catalogs on the market is there a company that sells direct replacements or is extreme improvisation always necessary?
thanks
p5861,
LMC has both options. A replacement of the original behind the seat and a "between the frame rails" option for 63-66 LMC Link . This should suit your needs fine for a 65. This is why I was originally asking what I could do for my 61. Hope this helps.
On my web site
another thought comes to mind in trying to think things through
before purchasing anything. if an under bed tank is used would this prevent dual exhaust from exiting at the rear?
I was looking at the exhaust layout of my 61 and I don't think that exhaust at rear will work. It appears that I will have to pull the exhaust out in front of the rear tires for the relocated gas tank to work..
Bummer....
Northdm
On my web site
