4 members (52Carl, Gdads51, JW51, Bisbee), 40 guests, and 3 robots.
Topics128,062
Posts1,055,845
Members48,428
#33926 10/02/2003 5:48 AM
Can anyone tell me where I can get the hoses for a windshiled washer pump for a 1968 chevy c10 ? Also since my truck does not have one hooked up can someone tell me how to hook it up?
Thanks again
The hoses can be purchased at places like NAPA or other good parts stores.
The hoses come off the pump which is mounted to the wiper motor itself (which is under the dash). I do not have the routing diagram for the hoses but one sucks the washer fluid to the pump and the other tow outlets go out to the firewall and up to the nozzles
Do you know the size of the hose to use? I am looking in my service manual and I am not seeing it.
Not positive but the small line should be 1/4 or 3/16 and the large line will be 1/4 or 5/16. If you talk to the right person at a parts store you might be able to get a sample (inch long or so) of each size of hose for a test fit.
