1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33926 10/02/2003 5:48 AM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Can anyone tell me where I can get the hoses for a windshiled washer pump for a 1968 chevy c10 ? Also since my truck does not have one hooked up can someone tell me how to hook it up?
Thanks again | | |
#33927 10/02/2003 5:52 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The hoses can be purchased at places like NAPA or other good parts stores. The hoses come off the pump which is mounted to the wiper motor itself (which is under the dash). I do not have the routing diagram for the hoses but one sucks the washer fluid to the pump and the other tow outlets go out to the firewall and up to the nozzles
#33928 10/02/2003 6:23 AM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Do you know the size of the hose to use? I am looking in my service manual and I am not seeing it. | | |
#33929 10/02/2003 7:28 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Not positive but the small line should be 1/4 or 3/16 and the large line will be 1/4 or 5/16. If you talk to the right person at a parts store you might be able to get a sample (inch long or so) of each size of hose for a test fit.
