1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Found this old remote oil filter canister and trying to figure out what it is. There are no markings on it, a top side fitting and a center bottom fitting. There are two dimples on the bottom but no drain plug. The inner tube goes straight through but there is no small hole in the tube. The lid bolt takes a 3/4" wrench. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | sound's like the 305-478 GMC V-6 canister well the 2QT one any how. . .
mine takes 3/4" wrench I do have 1QT canister that one takes a 5/8" wrench. . .
darn drain plug is 1-1/4" wrench. . .
Mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I don't think this would hold 2 quarts. There is no drain plug and what has me baffled is the lack of that small hole in the inner tube. Maybe the oil comes over the top of the filter cartridge. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | yup. . .mine don't have no drain's just a big bolt that comes threw the center of the globe into the engine. . .
Mike
| | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Maybe you could drill and tap a drain into it Bill. Lothar | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I think they used to use a siphon. I just have it sitting around, needs a good blasting and painting but I won't use it as I have one. | | |
