1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | I dont have access to assembly manual and am mounting my radiator core support, there is a carage bolt 2 rubber pads and a large washer and knut per side. I assume one rubber pad between frame and core support then one rubber pad on top of core support mounting braket, then washer and bolt. Is this correct? thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | close Dan, here ya go - make sure you have the "spacer", can be cut from tubing Bill | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Bill, Thanks I mounted with what I had to get the engine running before winter, I will have to get bottom shim and the spacer for both sides, Im sure I can make the spacers out of tubing or sheet metal rolled around some tubing. Thanks again. | | |
