| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | I was looking at them 5 ton army trucks. . .they put 14.00-20's and 16.00-20's on them as super single's they get more ground clearence and now the old 58mph army truck now run's 70mph. . .
Couldn't do tha the same thing by running 12R24.5's same hight yet just skinny enough i could still have the stability of dual rear wheel's ?
Mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 379MV6GMC-K3000, If we're talking about the old Budd wheels, yes the bolt pattern is the same whether the're 20", 22.5", or 24.5", hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Careful, There are a few different bolt circle diameters on the big 10 lug Budd wheels. For example, busses generally use a larger bolt circle. This catalog may help some http://www.accuridewheels.com/completeversion.pdfGrigg | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | OUTSTANDING! ! ! so i can put the moderen 24.5" budd rim's on and old 20" budd truck. . .
Thing about getting another army truck. . .
Mike
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | so i can put the moderen 24.5" budd rim's on and old 20" budd truck. . . Only if the bolt pattern is the same. What is the actual bolt pattern of the truck you are looking at? Grigg | | | | | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | Using a 24.5" wheel won't get you as much extra speed as it appears. The 22" tube-type tire and the 24.5" tubeless will have the same overall height, due to a shorter aspect ratio (height/width percentage) on the tubeless 24.5" tire. There are some very high profile tubeless tires for military use, but they're scarce and expensive. Jerry
| | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Yes but remember a 24.5 is a tubeless,it would be a 22in tube type and 20 in tube type would be a 22.5 in a tubeless. but the lug nut pattern would be the same. Just keep in mind the newer style Budd wheel would be what's called a hub piloted wheel. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | ACCTUALLY ! i was do at the Truck stop and they offer both hub and stud pioted rim's in 22.5 and 24.5. . . so as long as they meaure the same stud they can be swapped I did see an army rig with 11R22.5 T-831 traction tread's so a 24.5 will bolt right up. . . the old 11.00-20 is 42" actual inches tall as the 12R24.5 is 46" actual inches tall well in the G-177 Radail Mud Grip. . .they'll only be about 2" shorter then the 14.00R20 and 4" shorter than the 16.00R20. . . but i'll have an Over drive or 2 to make up the difference. . .
I'll just build another " mikeyplex " 15 spd. . .
MIKEYPLEX 15spd: mack 5spd 5th= .76:1 3 spd auxy 3rd= .85:1 giving you .61:1 whitch is what i did for my B61T it went from running 58mph@2250rpm to 72mph@2,000rpm. . . with out a tire size changed. . .doing the same for the 10 Ton but i'm swaping the 5spd for a 7spd a little better split for the KT cummins . . .
Mike D
