Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (klhansen, jay d, jmoore, 1 invisible), 129 guests, and 2 robots.
Topics128,288
Posts1,058,577
Members48,492
#338368 11/17/2007 6:58 PM
I need a new set of dust caps for the kingpins on the '53 1/2ton. Can I get these at my FLAPS?
Edit: Reason - I'm changing out the pins and bushings (fairly new) from my stock axle to one of Sid's dropped axles.
waldo53 #338475 11/18/2007 1:12 AM
I think that these are the same as a frost plug of similar design. Maybe you can get them by specifying the size.
1951 1 Ton Completed
truckernix #338524 11/18/2007 3:55 AM
If you're installing new kingpins and bushings, the caps should come with the kit. They did with the one I got from Moog. They're more of a belleville washer kind of deal. The dished side goes in towards the pin, tapped down to lock it in place, then staked in 4 places to keep it from coming out.
Bill Burmeister
LONGBOX55 #338552 11/18/2007 5:06 AM
Bill,
He mentions he is reusing a set that was recently installed in his rig...he is swapping axles.
Stuart
atomarc #338554 11/18/2007 5:13 AM
ooops. I missed that. Well, at any rate, the flaps might just have them. If you still have the old ones, take 'em with you to match them.
Bill Burmeister
LONGBOX55 #338833 11/19/2007 2:21 AM
Well, this brings up another question. The ones I put on just a few months ago I put dished-side out (kinda looks like a dome, ya know?) The kingpin set didn't have any instructions so I just put them in the way the old ones were in.
So - is it dish-in or dish-out??????????
waldo53 #338855 11/19/2007 3:14 AM
Out. The dish shape, when tapped down, helps lock it into place.
Bill Burmeister
LONGBOX55 #338891 11/19/2007 4:08 AM
lONGBOX, You're confusing me here.
waldo53 #338898 11/19/2007 4:16 AM
Sorry, I goofed on my last post. I'll explain a little better. The cap goes in so that the domed side goes out, the dished side goes in. The cap is then tapped down slightly to put pressure on it to make it lock into place and seal. Then it's staked in 4 places (a center punch works great) to lock it in perminantly.
Bill Burmeister
LONGBOX55 #339057 11/19/2007 6:31 PM
O.K. that's what I thought but just wanted to be sure. I'm off to town today to look for the caps.
Thanks a lot.
