1 members (baldeagle),
80
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I am planing on changing my tires and wheels. I now have 245/50/16 with 3 1/2 back spacing, 1 1/2 inch room on each side, unlimited up space on the rear anyone have a idea what will fit using a larger wheel 18in.? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 265/30/18 would be the correct plus size from what you have, 245/40/18 would keep the width about the same. Either way, expect the ride tt go very harsh with that short of a sidewall. Also, there won't be much load capacitly for any cargo.
Bill Burmeister | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thanks Bill,Well I don't need load capacity but can I go to somthing in the 245/ 50 series with 18' wheels? amd how do I determine the backspacing needed if different than the 3.5 I have now?
Zim
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Try this website - has a calculator to check all different scenarios. www.1010tires.com/TireSizeCalculator | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | britcon, that link comes up as not found, maybe defunct? gazim, a 50 series tire will be a bit taller than the 40, and will be taller than the tire you have now. As long as it's not sitting low enough to cause an issue with the tire hight, I don't see that as a problem, however, it will make the speedo read off (slower than actual). As to the backspace issue, what you can do is put some sort of stright edge, preferrably at least the same length as the wheel diameter, on the hub, then measuer back to check for clearance issues. Turn the spindle through its arc to check for obstructions and clearances. Essentially, you'll want to try to keep the rim centered on it's witdth on the spindle, but that's very difficult to get perfect. That's part of the reason newer trucks have such a deep offset. I'm not sure what you have for suspension, but you'll probably end up with around a 4" backspace. I wouldn't think that you would have to chang ethe backspace if you maintain the same rim width, though. BTW, I mentioned the load capacity from an experience we had at the shop with low profile tires on a truck. Had a customer that wanted a 245/45/16 on a '71 C20, 307 4 speed, 4.56 rear gear. Besides being so short in hight that he almost blew the engine up with too many revs, he kept blowing out sidewalls, The tires just didn't have enough capacity to carry the bare truck, let alone put a load in it. I'm just saying, check the tires specs out, make sure they'll carry the weight of the truck with a nice safety margin, alright. Just want you to be safe!
Bill Burmeister | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well I am printing out allthe good tips. Got the same thing on that link. I am more woried about the rear clearance as it is tighter. I have air bsg suspension on all 4. Height looks good but the side to side worrys me. Thanks all that answered. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Sorry about the link guys. Search 1010 Tires. That will get you the website - look for Tire Calculator. | | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 |
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Britcon good site I learned a bit, However no one seems to talk offset. If I get that wrong they wont fit. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thanks peg, I have to get some more facts before I order online. see above. | | | | | Joined: Jan 2004 Posts: 22 Apprentice | | Apprentice Joined: Jan 2004 Posts: 22 | gazin, At 1010tires I went to the ">tech" section and clicked on "wheel tech" and that took me to a paragraph on "offset" and at the bottom of that paragraph ia a "wheel Offset Calculator" link. Lots of good info. Had to read parts of it several times for it to sink into my thick skull. Good Luck.
Later JJ and 4 Keep the shiney side up
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | JJ will try again. Maybe I didn't look hard enough. Thanks.Zim
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | gazim - look under the tech section at the 1010 site. There is some info on offsets. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Britcon, I think you are on the same page as 4 on the tree. Thanks anyway I need all the advice I can get. If I shuck out the big bucks for new wheels and tires, they better fit.  | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Good info 4onthetree, I'm in the same perdicament, my 46 has an S10 front end and it looks a little narrow, using offset front rims would help but I didn't know where to start. I'll check it out. Thanks, Bob T
