1 members (papas52),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | After reading the post about DOT 5 brake fluid , it reminded me of something I go involved with. When you change your trans oil make sure it does not have GL-5 in it. It seems that API GL-5 is not compatible with "yellow metals" such as synchronizers and other bronze trans components. Forced to do some research on this, I found GL-4 is ok to use. Pennzoil Gearplus 80-90 with GL-4 is about the best choice IMHO. Just one more thing to watch out for.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Good stuf to know, If my 4 spd. had synchronizers I'd be worried | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kip's41,
I wonder if your transmission has countergears that run on bronze bushings, most do. This would fall under the category of a "yellow metal".
I have heard it takes many many moons before the sulphur or whatever additive it is that reacts with the brass/bronze to do any harm, and then it's slight.
Stuart | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Good point. Just checked the shop manual and according to that the counter shaft runs in Hyatt roller bearings. However there is something wrong in there as the trans. howls something terrible. I’m just beginning to pull it out to rebuild. I’ll know shortly and be sure to refill with GL-4. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just curious....checking the jugs of gear oil I have in the shop has them all listing GL-5, GL-4, GL-3 applications which I run in my 1985 NWC T5. I've only got about 3k since installation, changed it out after 1K, filtered the oil to see if I could detect any metal (couldn't) and the transmission shifts like butter and is quiet. There was some question as to whether Dextron should be used in the NWC transmissions...I chose to go with some advice from a box builder, but he didn't mention the GL-4 info. You mentioned the Pennzoil Gear Plus 80-90....did you find any other manufacturer brands that you might recommend? Is the Pennzoil available in most FLAPS? If it's readily available, I might just drain and filter again and transition to the GL-4. Thanks for the info.
Dave | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Around here it's available at the tractor supply stores in 5 gal or some call it 35 lb pails . Could not get an answer from my Napa guy, except he would look into it. The Pennzoil part #'s are Qt - 21176 35lb/5 gal pail - 4804
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Just an update. My Napa guy got back to me on the use of Napa/Valvoline/Ashland 80-90 gear oil in Stovebolt trans and rears. Even though Napa specs say GL-4,GL-5, their product will NOT harm "Yellow Metals" such as synchronizers and bronze bushings. The part # for a 35 lb/5 gal pail is Napa 75-213.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | An update on my comment above. Now that the transmission is apart I see that the counter shaft does run on roller bearings, BUT the reverse idler gears run on two bronze bushings. So I do need a lube that is friendly to yellow metal. | | |
