6 members (GMCJammer51, Gdads51, Joe H, Otto Skorzeny, DadsFirstPickup, Phak1), 99 guests, and 2 robots.
Topics128,056
Posts1,055,792
#3378 02/25/2005 4:16 AM
I've noticed my rear end appears to be leaking from the front and back side, top and bottom. As I start thinking about putting a finish on it (tell me what you used to refinish yours for an extra level of gratitude), I was wondering if there are gaskets on both sides and if they are commercially available. If they aren't sold, what do you use to replace the seals?
Thanks!
#3379 03/01/2005 4:33 AM
Either I'm the only one who's ever wanted to change the gaskets on a rear end, or the answer is so easy everyone else knows the answer.
Please humor a fool either way.
#3380 03/01/2005 4:49 AM
Well I'll take a stab at it. Gaskets are used where the front pumpkin bolts into the housing and where the rear cover bolts on also. I would think they should be available from many of the truck part dealers, Jim Carter, Chevy Duty ect.... As far as what to paint the rear housing with, from the factory they would have been finished in a satin black color (semi gloss). Preference is up to the painter on brand and type of paint. Myself when I get to that part I will probably use Rust-O-Leum Satin Black. Gaskets and seals should also be available for the axle shafts and the ball on the back of the transmission. Check your breather on the axle housing to make sure it is not stopped up with dirt. Hope this helps.
#3381 03/01/2005 4:52 AM
Might want to check the transmission oil level to see if seal at top end of torque tube is allowing transmission oil to leak past it and over fill the differential.
