1 members (RLB),
95
Mod | | | Forums66 Topics128,090 Posts1,056,378 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | All & Any,
Does the late model blazer gas tanks fit between the frame rails of a 60-62 like they do for 63-66? If not, is there an aftermarket tank that will work or another late model vehicle that would work?
Thanks all.... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I don't know which Blazer tank you're talking about. The one I have came from Coleman's Military Surplus. They were an 80s Diesel tank. However they have no more of these, probably because they sold for 25.00. That tank will fit the 3100 AD (not the 3600). I don't know if it will fit your application.
~Jim
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | This is one of those things I always try to warn 60-62 owners about. I've taken measurements under my frame and haven't found any commercially available that fit where and how I want. That's not to say there isn't anything out there, I just haven't found it yet. There are custom fab shops that can build to your specs - How much $ you got? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | bigmacdaddy is right, however after you've bought a few tanks that don't fit, like me, then that custom $ tank is not so expensive. I have found you must be very careful when measuring. On mine the frame rails were wide enough but I didn't notice the spring shackle nuts were protruding just enough that my Blazer won't work.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Big Chevy I'm suprised your tank wouldn't work. I put one in mine without any problems.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You probably did not replace your springs. I replaced mine with a TCI kit which puts the spring shackles directly under the frame rail.
~Jim
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Hmmmm....I've got a '62 Suburban, with a between-rails tank that works with the spare tire carrier. (factory application). I'd like to put a new tank in there, but haven't found that anyone makes them yet. However, the '57 Chevy station wagon tank I have looks like it'll be a close match, except the cut-out for the tire is on the top, rather than bottom half of the tank (as the spare tire well in the wagon was in the floor, not under the floor). It wouldn't be a direct bolt-in, but it's a starting point. A '55-'57 Chevy car tank might also work...they're fairly compact. and the filler tubes are also available.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Nov 2007 Posts: 3 New Guy | | New Guy Joined: Nov 2007 Posts: 3 | hi, theres a two opptions 69-72 blazer tank that bolts right to the frame if you have coil springs and theres a alum. tank that made just for you truck tuckersparts.com sells them. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Big Chevy, did you replace them to run bigger tires?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yes, I replaced them so if I decide to swap to a wider tire I would have the option. That was my secondary reason; my first reason was to soften the ride.
~Jim
| | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | Thanks for the feedback. I will probably opt for the aftermarket aluminum tank option if I still have funds available  | | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | i was looking to do an under bed replacement on a 65 chevy short step half ton. any advise?? out of all the aftermarket catalogs on the market is there a company that sells direct replacements or is extreme improvisation always necessary?
thanks | | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | p5861, LMC has both options. A replacement of the original behind the seat and a "between the frame rails" option for 63-66 LMC Link . This should suit your needs fine for a 65. This is why I was originally asking what I could do for my 61. Hope this helps.
| | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | another thought comes to mind in trying to think things through before purchasing anything. if an under bed tank is used would this prevent dual exhaust from exiting at the rear? | | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | I was looking at the exhaust layout of my 61 and I don't think that exhaust at rear will work. It appears that I will have to pull the exhaust out in front of the rear tires for the relocated gas tank to work..
Bummer....
Northdm | | |
