4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
I dont have access to assembly manual and am mounting my radiator core support, there is a carage bolt 2 rubber pads and a large washer and knut per side. I assume one rubber pad between frame and core support then one rubber pad on top of core support mounting braket, then washer and bolt. Is this correct? thanks.
close Dan, here ya go - make sure you have the "spacer", can be cut from tubing
Bill, Thanks I mounted with what I had to get the engine running before winter, I will have to get bottom shim and the spacer for both sides, Im sure I can make the spacers out of tubing or sheet metal rolled around some tubing. Thanks again.
