5 members (WICruiser, Gdads51, 55shaker, Ponchogl, DadsFirstPickup), 121 guests, and 1 robot.
Topics128,054
Posts1,055,782
#335726 11/10/2007 11:12 PM
The switch cylinder is a 59 with the small hole to remove. I can insert a stiff wire, feel a spring compressing, but the darn thing won't release. What am I doing wrong? Thank's guys.
Mike
Riding in the Passing Lane
Turn it counterclockwise A little further.
1972 Chevy c10 Cheyenne Super
It won't turn, would a wee bit of penetrating oil hurt? Don't have a key for this one, trying to replace with a new keyed cylinder.
the pinhole allows the cylinder to be turned backwards with the key if you don't have a key, it will never turn, has to be drilled out
Martin,
Red's right, you need the key. You might try useing the key that came with the new cylinder - worth a try.
good luck,
HC
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
I bought the new clyinder because there was'nt a key with the old one. Tried useing the new key but it won't turn the cylinder, although it did fit in nicely. When drilling out the old clyinder, how much danger is there of ruining the switch? Going to try tomorrow.
You don't drill out the entire cylinder. Drill about a 3/8" hole in the center then dig the spring and pin pieces out of the hole. Once the pins are out of the way, the cylinder will turn for removal.
MartinMikey,,, If you havent drilled it out yet, I have a string of about 50 or so G.M. ignition keys. One of them is SURE to fit.
If you promise (stovebolter promise) to send them back to me,,i'll send it to you and you can go thru them till you find one to fit.
Youre more than welcome to try it but, I HAVE to have it back.
OR,,,, If you want to send me your old lock cylinder and new key tumbler part,,,I'll switch them for you. No $$ involved.
Marty
Apprentice
Apprentice
take your switch to a local locksmith he can fit a key to it if there good, I work @ lockshop we fit keys to ignitions
all the time it would cost about 12 dollars to have it done @ my shop, if you have the original switch the key they make may fit the door as well thats how it should have come from the factory
Apprentice
Apprentice
if you do drill it there should be a code stamped on it from the factory if its the original cylinder that code will get you a door key sometimes the code was stamped on the door lock cylinder you could have a key made to the door that might fit the ignition if its original parts
Took mine to the locksmith as suggested above. $10.00 and no hassle. Well worth it.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Thanks for all the advice guys. I think I'll try the lockshop route. Standby delux54panel, I may take you up on you're offer. I would send you my switch to insure we wound'nt lose you're keys.
V
V Offline
I know this deosen't matter now because you do not have a key to turn but, I just read in the 1948-1951 Chevrolet Truck Shop Manual that you have to turn the key (clockwise), stick in the wire into the hole to feel the spring and the TURN THE CYLINDER/KEY CLOCKWISE a little bit more to remove it.
