| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | I am putting a small block in my 49 GMC longbed. My current torque tube rear is 56" between drum backing plates so I am using this number as the basis for replacement. I was told to look for an s-10 4x4 rear as they are the same width. The problem is that every rear is short. what I am finding is that 2 wheelers are 48" and 4x4's measure 53" which I am scared will not clear the frame rails. Does anyone know what years s-10 would be 56" or can suggest any other rears to look for. Thanks, vik | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There's a whole page on this in the tech tips section: http://50chevy.freeservers.com/Suspension_Widths.html#SuspensionIf your S-10 has 2" wide brakes, this puts the wheel flanges at about 57", which is going to be too narrow. I have a '66 Chevy pickup axle that has 58" between drums, 62" between flanges. It has a 3.07 gear ratio and six lug bolt pattern. That is my #1 suggestion for interchangability. Its slightly wide but not noticable, about 1/2" per side according to my measurements on my Chevy. The spring perches have to be changed, though, the 66 is out of a coil spring truck.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Whoever told you the S-10 is the right width doesn't have the whole story and may have mislead you.
Do you want the five lug pattern or the six? Since the S-10 is five I'll guess that is the direction you want to do. I used the rear from a '73 Chevelle under mine. Its 62 inches wide across the wheel mounting face, which I think is the better place to measure. Measuring backing plates tells you if it will fit your springs, measuring the wheel mounting faces tells you where the wheels will end up under the fenders.
The 62 inch wide axle I used seems to work about perfect. The downside of the Chevelle is you have to cut the coil spring stuff off and weld on leaf spring pads. I've been driving mine five years with that Chevelle rear under it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
