4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Hello, Do any of you guys know what a feller could use to replace the RED and Green lenses in the dash cluster on a 64? You know the OIL, GEN, turn sig..etc? I have my dash cluster apart and see that they are some very thin colored plastic parts. Where to get them or what I could use to replace them would be my question. I am assuming that you would want something that won't melt too quickly.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used translucent colored construction paper from Hobby Lobby, it was the plasticized stuff, kinda has a sheen to it | | | | | Joined: Nov 2007 Posts: 18 New Guy | | New Guy Joined: Nov 2007 Posts: 18 | You can also go to a good pro-audio music shop and ask for the filter gels that bands use for their stage lighting. A brand named Roscoelux is one that offers a diffusion material that is very close to the original "textured" looking surface of the stock lenses. Maybe the drama dept at your local school would have some also. Only problem-- expensive, but very heat resistant! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 20” x 24” sheet, $5.45, that’s cheap enough and you could supply the whole neighborhood with that much material. Probably cost you more to ship it than the material costs. http://www.northernsound.net/Sales/Filters/filters/rosco/roscolux.html Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I just went to the hobby shop, got a sheet of .010" clear sheet plastic and some transparent paint (I used blue in mine). A couple of coats of the paint, a little epoxy, and presto! New lenses, and cheap, too. If you wanted something a little more translucent, you could use sheets with a slight texture to them, or possibly a .005" white styrene sheet. That's thin enough to let light through, but has a slight texture to it.
Bill Burmeister | | |
