9 members (GRNHydra, 1955 1 Series, NAPCOStormTrpr, joe apple, Charles in CA, klhansen, DBJ71SuperCustom, dt235sd, 1 invisible), 101 guests, and 2 robots.
Topics128,079
Posts1,056,286
Members48,441
#336137 11/11/2007 11:56 PM
PBO
Offline
Apprentice
Apprentice
Wanting to put a power disc front suspension on my Grandsons project. Trying to keep low-buck and scouting the wrecking yards, found a pretty clean system on a 87 GMC Suburban, realizing that this will change to a 5 hole pattern, does anyone know if it will fit by simply replacing the spindles at the ball joints? If not, does anyone out there know what will? Thanks in advance for your help.
PBO
If I am doing this right this should be a link to a similar question.
https://www.stovebolt.com/ubbthread...4&topic=0&Search=true#Post242062
You may have to copy and paste?
#336500 11/12/2007 11:14 PM
IF YOU CAN FIND 71-72 CHEVY/GMC 1/2TON 6LUG ALL WILL SWAP OVER AND KEEP 6LUG SET UP AND FOR ABOUT 700.00 YOU GET A NEW KIT THAT REBUILDS EVERY THING FROM TIERODS,BALLJOINTS,AND SPINDALS OUT. I GET ALL MY PARTS FROM TUCKERS CLASSIC IN LAS VEGAS(TUCKERSPARTS.COM)
Riding in the Passing Lane
The 71-2 are 5 lug. The only way to keep the 6 lugs are to buy aftermarket rotors from one of the specailty shops. You can use the 5 hole rotors & change the rear axles & drums & use 5 hole wheels. There is something to watch for in exchanging the axles but I don,t remember what it is. Maybe a fellow bolter will chime in & help.
1972 Chevy c10 Cheyenne Super
PBO
Offline
Apprentice
Apprentice
For those interested; I put a '87 1500 Suburban front end in the '64, it was a truly easy swap, I took the crossmember and all components, including power steering pump and master cylinder/diaphram which I have not yet installed.; it bolted right in and was snug, had to drill one hole on each side and elongate one on either side. The '64 doesn't have the "notch" in the frame that the '87 does, Brothers makes a "convesion plate" the allows the boltup of the 87 powersteeering controller. Then, to convert the rear end to a 5 lug pattern I put in a '72 1/2 ton rear end on the '64 frame, total cost front and rear $415.00. PBO
