0 members (), 118 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
Need to know what parts cause The three on the tree shifter to be hard to shift I replaced the plastic busings on the shift rod
but did not seem to help.
What would be the next logical place to check?
This is on a 1959 chevy 1/2 ton stepside with the orginal 283cu
V8 truck.
Here's a link to the adjustment procedure:
http://chevy.tocmp.com/shop/1955truck2/55ctsm0704.htm
You Tube
Thanks for reply
Here is a picture link to shift linkage in question
http://s189.photobucket.com/albums/z24/focus2002_2007/?action=view&current=100_1328-1.jpg
This has never been removed or changed it seems to have worn over time so if adjustment does not work then what else could it be Control shaft spring weak?
Barry
The manual states "proper adjustment procedure is important". I would follow all the steps in order and then you should be able to figure out if the shift box is worn out or if some other problem like tired motor mounts are causing your grief. Use grease in the shift box...gear oil will leak out. The box is aluminum and can wear out over time but you can get a rebuilt one for about $50.00
You Tube
When I rebuilt my engine and tranny, I too had issues with the shift linkage when it all went back together. Here's what I found. First, you need to get familiar with the positions of the shift arms on the side of your tranny. When I rebuilt the transmission, I photographed the positions of the arms in all the gears. (See my webshots pictures at http://community.webshots.com/user/geezer). I then used these photos when I was underneath the truck to make sure that whatever gear I thought I was in was indeed correct. Then, I went up to the cab and put the shifter in neutral. Went back to the tranny underneath the truck and made sure that the tranny shift arms were in neutral. Next and the most important, went to the shift box on the column. The shift box needs to be absolutely perfect (especially if it has been rebuilt and tight as mine was) to make sure that the shifter lug passes smoothly between the upper slot and the lower slot. You may need to loosen the shifter box to the column, rotate it slightly left or right and possiby up and down the column to align the two slots perfectly. It only moves about 1/2" up and down as it is caught with a tab in a slot on the column. Loosen the clamp nuts on the shift rods at the box to allow you to eyeball and adjust the slots inside the box. You can usually do a better job of doing this if you take the cover off the box, remove some of the grease and then watch the slots and tab. Once the tabs are aligned, clamp down on the shift rod nuts and also make sure that the shifter box clamps are tight on the column. This is a try and see adjustment procedure. You may need to do it several times to get it right. When everything is correct, everything adjusts to the neutral position. The shifter arms on the tranny are correct in neutral, the lug passes cleanly between the two slots on the shift box and the shifter arm in the cab is in the correct position. Takes time to get it right. Once you do that, you may experience some tight shifting from the cab so go back and check the tab and slots in the box. That's where the shift arms and nuts may need a bit more nudging. Good luck!
Country Roads, West (By God) Virginia
Focus,
I'm not a 'three on the tree' expert, but have seen the detents and bushings in the actual transmission sidecover go to heck in a hand basket. Regardless of all the splashing gear lube, this can make the vehicle hard to shift.
If you disconnect all the shift linkage from the transmission, you should be able to single out the problem...either the shift box and related bushings or the transmission sidecover and its mechanicals.
I remember a post awhile back where a sticky shift problem with a column shift was actually a worn support or bearing right up on top of the column, under the shift handle itself. Good luck.
Stuart
Curt_B
you said
:Use grease in the shift box...gear oil will leak out
Will wheel bearing grease work?
FOCUS: That picture you posted; http://s189.photobucket.com/albums/z24/focus2002_2007/?action=view&current=100_1328-1.jpg
I had no idea gear oil went in where you have that arrow pointing. Would that also apply to a 1953?
Here's a picture of mine.
http://img.photobucket.com/albums/0603/auntiemame/cars/212_1287.jpg
Then again, theres a place that looks like where one would add oil a bit further down the column. Here is a shot of that:
http://img.photobucket.com/albums/0603/auntiemame/cars/212_1288.jpg
Should I check the levels of and add oil to either of those places?
Sorry for the hijack but thanks for the answers.
Us girls like them ol trucks too!
New Pics of my 53 Chevy:
Side: http://tinyurl.com/3xtgfa
Dash: http://tinyurl.com/2npafu
Front: http://tinyurl.com/3dhlkv
Savage
Originally Posted by Focus
Curt_B
The manual says use soft,smooth grease. Wheel bearing grease is ok.
Rsavage:
Your first pic is of the shift box. The manual states it is lubricated permanently and only needs checking in the case of hard shifting and grease goes in there. In your second picture that square plug is on the steering box and steering lube goes there if required. That one's a long story...do a search for steering lube.
Curt B.
You Tube
Thank you Curt! I will search the boards for it.
Savage
Ok, for the shift box, that round tab came right up. Inside was one solid chunk of old grease. It was gummy. I'll get new grease for that.
As for the steering lube -I'll ask the parts store what they have. Thanks again!
Savage
Something else you can check - the shift lever inside the cab. It has a wire type spring and rubber bushing inside that can be missing or broken. It also needs to be lubed with light grease but needs to be taken apart to do so.
Fred
Ah! Cool! I had no idea. Yanno... the screws that hold the shift lever onto the steering column are loose as well. I don't think they're the original screws. Either that or they've been all cross-threaded and have lost their tightness.
I bet if I replace those, it might help a smidge. I'll check for the spring and bushing too.
I'll still be taking it to a transmission place but all this other stuff is just great to know.
smile
Savage
rsavage,
Did you just add more grease or clean the old out someway?
Thanks to All who responded,
Thats what makes this site great!
I will check out all suggestions as to the binding shifter problem.
Focus
The old dry grease will probably do a good job of preventing new grease from doing any good. It should be disassembled paying close attention to how the spring is oriented inside, cleaned in a parts washer, inspected for wear, and then lubed, re installed and adjusted if one wants to do it right. The rod and arms shouldn't wear much but the aluminum housing can get real sloppy. Good luck.
Curt B.
You Tube
I actually cleaned it out pretty good without taking it apart. I'll get brave and take it apart at some point but for now, all the grease was really just kinda balled up and it came out on the tip of a screwdriver. I dug around all sides, up and down with the screwdriver digging out a bit more and then took a skinny hooked scrubber thingy (kinda like a baby bottle nipple cleaner) and worked that around. I know I didn't get every bit but I got at least 98%.
I'm going to go fix the shifter on the column in a few. It's slightly loose and needs new screws to make it tight. smile
Thanks everyone.
Savage
Hard and sticky shifting is a problem solved with patience and perseverance. New bushings, rebuilt shift box, etc. all help, but adjustment is pretty critical. Start with the transmission shift arms and work your way up to the shift lever inside. Good luck. sometimes it seems to be luck more than skill.
