5 members (Otto Skorzeny, Hotrod Lincoln, jay d, ‘37ChevyPU, Bill Hanlon), 175 guests, and 1 robot.
Topics128,109
Posts1,056,262
Members48,439
#333652 11/06/2007 4:59 AM
* Offline
Been to three store and no one can help. I am wanting to paint the bed bolts, they are zinc, was told I need to prime (special primer) before paint but what primer is needed so the paint won't come off. please help.
*Brian #333702 11/06/2007 11:01 AM
I neve had a problem with painting over zinc bolts. I would maybe first hit them with an abbrasive pad or maybe fine sand paper. use the same primer as you use for the rest of the vehicle. Just my opinion but I would not lose sleep over it.
I agree, sand them just like you would any other part of the truck and use the same primer and paint that will be applied to the truck body. Should be fine.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
* Offline
Thanks for the info. I think it will be a little hard to sand around the stamping on the heads of the bolts thats why I was looking for a primer. Anyone else got an idea,open for anything.
A wire brush will work fine, I have one mounted on an old bench grinder that is great for small parts.
Paint & Body Shop moderator
soak the bolts in POR15's Metal Ready. It will lightly etch the surface, then deposit a phosphate coating. or use self-etching primer.
