8 members (TUTS 59, wilbur53, Joe H, tclederman, Charles in CA, kades51, 2 invisible),
74
7
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Okay, I need some EXPERT advise regarding the installation of the rocker shaft/s on my 216 engine. I checked the shop manual and it does not explain in detail the position of the rocker shafts when installing to the cylinder head. The rocker shaft sections are hollow to allow oil flow through the shaft and out each individual rocker arm oiler holes. This rocker shaft sections can be installed with the oiler holes on top or 180 degrees out with oiler holes towards the bottom. Can anyone definitively tell me which position these shafts are mounted? Oil passage Holes up or holes down? Presently they are pointed down, and I notice only small ammounts of oil oozing out of each rocker arm oil port (on top) of each rocker arm. It does not seem adequate to spray onto the upper push rod pivot points or the valve springs and valve guides after in lubricates the rocker arm to shaft bushing. Have I got these rocker shaft sections installed upside down? Thanks For EXPERT responses
Best Regards Will
| | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | The holes point down. Once the oil warms up and the rocker shafts fill you will be surprised at the amount of oil flowing thru the holes in the rocker arms. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Yep, what Jim said. Down is correct. If you think about how small the feed line is & how long it takes to fill the shafts, if the holes were on top the rockers would be running dry for a long time. With the holes on the bottom at least they get some oil while the shafts are filling.
