4 members (‘37ChevyPU, Steelonsteel, dt235sd, carbking), 67 guests, and 1 robot.
Topics128,051
Posts1,055,766
#336090 11/11/2007 8:59 PM
Apprentice
Apprentice
needing info on where to buy engine overhaul kit for my 1952 one ton dually. the engine has #'s as follows (A 270797053 E). where do i start to find a complete overhaul kit.
shorthood2006,
I don't know where to find a 'kit'. If you haven't torn the engine down yet to measure the bore, rods and mains, it will be pretty tough to figure out where you are going with this rebuild.
If you were to find a 'kit' with say, STD main bearings, then had a machine shop tell you the crank needed to be ground .010 under, you might be up the proverbial creek without a paddle.
This is how I see the situation...but I might have bum vision...OR, you might already know exactly what you need!
Stuart
atomarc #336138 11/12/2007 12:02 AM
Talk to Patrick Dykes... he has or can get all the parts you need for a rebuild or a hop up. I got some venolia pistons from him several years ago. They were so pretty it was almost a shame to bury them in my 302.
Apprentice
Apprentice
thanks guys. i am starting to take the engine out of the truck.Just getting started. thanks alot... im sure i will be back to ask more questions.
shorthood2006 #336147 11/12/2007 12:35 AM
Apprentice
Apprentice
are there discount stores to purchase the pistons, rings, bearings, valves, etc... I like to shop the internet.
