0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 20 Apprentice | | Apprentice Joined: Oct 2007 Posts: 20 | needing info on where to buy engine overhaul kit for my 1952 one ton dually. the engine has #'s as follows (A 270797053 E). where do i start to find a complete overhaul kit. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | shorthood2006,
I don't know where to find a 'kit'. If you haven't torn the engine down yet to measure the bore, rods and mains, it will be pretty tough to figure out where you are going with this rebuild.
If you were to find a 'kit' with say, STD main bearings, then had a machine shop tell you the crank needed to be ground .010 under, you might be up the proverbial creek without a paddle.
This is how I see the situation...but I might have bum vision...OR, you might already know exactly what you need!
Stuart | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Talk to Patrick Dykes... he has or can get all the parts you need for a rebuild or a hop up. I got some venolia pistons from him several years ago. They were so pretty it was almost a shame to bury them in my 302. | | | | | Joined: Oct 2007 Posts: 20 Apprentice | | Apprentice Joined: Oct 2007 Posts: 20 | thanks guys. i am starting to take the engine out of the truck.Just getting started. thanks alot... im sure i will be back to ask more questions. | | | | | Joined: Oct 2007 Posts: 20 Apprentice | | Apprentice Joined: Oct 2007 Posts: 20 | are there discount stores to purchase the pistons, rings, bearings, valves, etc... I like to shop the internet. | | |
