1 members (klhansen), 113 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
#33576 01/12/2003 5:17 PM
I need a recommendation. SHould I buy new or have a spring shop recondition my front and rear leaf springs for my 45 GMC 1/2 ton?? I also want to lower the front a couple of inches, can they also re-shape them for this?
If so, can anyone recommend a shop in the N.England area that does this.
I would not feel comfortable riding on springs that have been altered from stock shape after all those years; unless the heating and recurving is done right you could end up with brittle springs. It is much easier to remove a leaf or two if you want a slightly lower and softer ride. Remember to disconnect the steering linkage before altering the ride height so you don't bind/break anything. Here is a page that describes the procedure on a TaskForce. How far you can drop will be limited by the rubber spring snubber on the frame, so take some measurements; you may want to buy monoleafs after all.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
