1 members (Forty9), 64 guests, and 2 robots.
Topics128,043
Posts1,055,610
#334451 11/07/2007 11:04 PM
Hello, I'm sure this has been asked a hundered times. I tried a search but didn't find what I was looking for. What can I safly and reliably cruise my 1960 C-60 at? Or better yet what rpm would be the target at cruise? Thanks for any reply on a subject i'm sure has been beaten into the ground.
240,000 worker bees!
1960 Two ton Chevy
58-62mph should be safe. . .the best 3,000rpm is Max on the GMC V-6 or big block V-8's inline 6's should hold 3250rpm and the small block v-8's can handle 3500rpm. . .
As a rule of thumb I use 3,000rpm as my max speed across the board. . .
Mike
1962 GMC K3000, GMC-379 V6.
What engine, do you have an overdrive or is 1:1 your top gear, what rear end ratio, and how tall are your tires. engine will tell us the RPM range and the rest I can plug in and give you approximate top speed.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
V
V Offline
I've had the firetruck up to 55 but I wouldn't push it. As for a C60, I'd guess you would be in a simular size motor and truck as mine.
Flat out on level ground..... my '49 runs happily at 50mph...of course that gets slower (or faster) depending on hills and/or other terrain..........
Michael
speed is relative..... just not one of mine....lol
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
my K-3000 run's 62.5mph@3,000rpm the 379M-V6 seem's happy at 3,000 rpm.
the B61T run's 72mph@2,000rpm I changed the mack triplex for my own version of the triplex. I combined a later model mack 5spd OD tran's with 3spd auxy now i got 2 OD's then i added a turbo to the 711END to create a 711END-T,stock 58mph@2250rpm now 72mph@2,000rpm. . .I gained 14mph and 2mpg. . .
mike. . .
Freq2002, I'm running a 261, my top gear is 1:1, I am running 20 inch tires. As far as my rear end is I do not know the ratio. It's a two speed vac operated out of a 59'. I had a chipped gear set when I got the truck and I just replaced the third member. Apparently I had a 59 diff in it. I suppose the result of a early truck manufacture during a model change. Thanks!
1960 Two ton Chevy
My '62 GMC 6500 with a 478 V-6 would go 62. But the truck was in real good mechanical shape and I would only run it that fast for short spurts.
50 to 55 seemed much more of a favorable cruising speed.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
sound's about right. . . i had 1980's C-60 with a 350 that would run 65mph@3250rpm. . . with some over sized tire's. . .I put 11.00R20 T-831 Firestone tire's under a 8.25-20 Truck. . .
what will that 478 Hold for R's about 2500 ? 2750 top's ?
mike
Mike,
The truck didn't have a tach. It had a place for it, but it was blank. It had all the other gauges, air, oil, water, ammeter, but no tach.
But it was probably maxed out to what a 478 goes to at 62 MPH. I'd have to look it up to be sure.
GMC 9500 Fan
Detroit Diesel Fan
If the 478 would cruze 3,00RPM I would swap out my 379M-V6 or a 478M-V6 in a heart beat. . .
Mike. . .
