1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Hello, I'm sure this has been asked a hundered times. I tried a search but didn't find what I was looking for. What can I safly and reliably cruise my 1960 C-60 at? Or better yet what rpm would be the target at cruise? Thanks for any reply on a subject i'm sure has been beaten into the ground.
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | 58-62mph should be safe. . .the best 3,000rpm is Max on the GMC V-6 or big block V-8's inline 6's should hold 3250rpm and the small block v-8's can handle 3500rpm. . .
As a rule of thumb I use 3,000rpm as my max speed across the board. . .
Mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | What engine, do you have an overdrive or is 1:1 your top gear, what rear end ratio, and how tall are your tires. engine will tell us the RPM range and the rest I can plug in and give you approximate top speed. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've had the firetruck up to 55 but I wouldn't push it. As for a C60, I'd guess you would be in a simular size motor and truck as mine. | | | | | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Flat out on level ground..... my '49 runs happily at 50mph...of course that gets slower (or faster) depending on hills and/or other terrain.......... Michael
speed is relative..... just not one of mine....lol \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | my K-3000 run's 62.5mph@3,000rpm the 379M-V6 seem's happy at 3,000 rpm.
the B61T run's 72mph@2,000rpm I changed the mack triplex for my own version of the triplex. I combined a later model mack 5spd OD tran's with 3spd auxy now i got 2 OD's then i added a turbo to the 711END to create a 711END-T,stock 58mph@2250rpm now 72mph@2,000rpm. . .I gained 14mph and 2mpg. . .
mike. . .
| | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Freq2002, I'm running a 261, my top gear is 1:1, I am running 20 inch tires. As far as my rear end is I do not know the ratio. It's a two speed vac operated out of a 59'. I had a chipped gear set when I got the truck and I just replaced the third member. Apparently I had a 59 diff in it. I suppose the result of a early truck manufacture during a model change. Thanks!
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | My '62 GMC 6500 with a 478 V-6 would go 62. But the truck was in real good mechanical shape and I would only run it that fast for short spurts.
50 to 55 seemed much more of a favorable cruising speed.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | sound's about right. . . i had 1980's C-60 with a 350 that would run 65mph@3250rpm. . . with some over sized tire's. . .I put 11.00R20 T-831 Firestone tire's under a 8.25-20 Truck. . .
what will that 478 Hold for R's about 2500 ? 2750 top's ? mike
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Mike,
The truck didn't have a tach. It had a place for it, but it was blank. It had all the other gauges, air, oil, water, ammeter, but no tach.
But it was probably maxed out to what a 478 goes to at 62 MPH. I'd have to look it up to be sure.
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | If the 478 would cruze 3,00RPM I would swap out my 379M-V6 or a 478M-V6 in a heart beat. . .
Mike. . .
