| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 11 New Guy | | New Guy Joined: Nov 2007 Posts: 11 | I'm new at this, so please be patient. I've tried the "search" function, and "no luck". I want to install my 1971 Chevy body (C20, 2wd) on my 1986 GMC frame (1500, 4x4, highly modified). I was told any 1970-72 cab & front clip would work. Can anyone confirm this installation? Any ideas or suggestions would be greatly appreciated. Thanx! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen a '73 body on a '72 frame, so I would imagine the reverse can be done too. Don't be surprised if small differences cause a lot of work. '73 and '87 are the same series and should be very similar.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The best advice that you will get here Jeff is this, measure, measure, measure. That swap may have been done before and if someone here knows about it you will get some great info. But if not, measure, measure, measure. Also check with other sites. Club Hot Rod is a great site for misc. information. http://www.clubhotrod.com/
~Jim
| | | | | Joined: Nov 2007 Posts: 11 New Guy | | New Guy Joined: Nov 2007 Posts: 11 | Thank you for the response. I thought there'd be huge difference in cab mount width & length. I'll post some photos when I can locate a camera. | | |
