0 members (),
47
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33543 03/27/2002 5:10 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hi guys,
I'm working on a '79 *amaro for a friend. Its got a '68 327 and a set of "434" casting iron heads with 60 CC chambers. Assuming a .030" bore, flattop pistons w/ 4 valve reliefs, and a .045 head gasket, what would the comp ratio be?
We have no idea what shape this motor is in. It runs, but no idea of cranking or oil pressure. How hard is it to pull the oil pan on a 327 and have a look around?
Where are the numbers on a TH350 so I can ID/date the tranny?
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#33544 03/27/2002 10:47 PM | Joined: Mar 2002 Posts: 12 Junior Member | | Junior Member Joined: Mar 2002 Posts: 12 | The engine should have around 9-1 compression. Pulling the pan with the engine in the car would be a major pita.
1953 M38A1 (Military Jeep) 1962 K10 1963 FC170 (Ugly Jeep)
#33545 03/28/2002 3:45 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Assuming that there is no X-member or anything in the way, does the oil pan just unbolt and fall off like a stovebolt? I can leave the front cover and stuff on, right? Sounds like stupid question time, but I've never pulled a pan on a SBC before.
Is it OK to unbolt a rod cap, examine the bearings and torque it back in place?
chip
#33546 03/29/2002 6:38 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Chiphead-I once helped a friend of mine drop the oilpan off of the 3.8 Cevy V-6 in his 80 Camaro. It was not a "huge" deal, but not a walk in the park, either. We had to undo and remove through bolts holding engine mounts together, then used a floor jack with a block of wood to carefully tip engine up off of it's mounts. Oh yeah, we also had to disconnect the exhaust pipes from the manifolds (that was the hard part). Once the engine was tipped up, we placed 2x4 blocks between the engine mount halves to hold engine up, undid oilpan bolts and dropped it onto crossmember. It JUST cleared coming down and towards the rear of the car. This might not work on a small block, because it's longer, but it's just a suggestion, and may give you a place to start. Wannabe
"Don't expect anything and you'll never be disappointed"
#33547 03/30/2002 6:19 AM | Joined: Mar 2002 Posts: 12 Junior Member | | Junior Member Joined: Mar 2002 Posts: 12 | I am not sure but i think that the bellhousing on the TH-350 would hit the tranny tunnel before you could lift it up enough to remove the pan. The pan comes off like a stovebolt. You dont have to remove the timing cover. Removing a main and rod cap won't hurt anything as long as you keep it clean and put them back on the same way they came off. Make sure that they are torqued to spec.
