Brrrr
place holder
5 members (delky, Otto Skorzeny, FishinToms53, SmalltownTRKGuy, Scott), 153 guests, and 5 robots.
Topics128,271
Posts1,058,414
Members48,485
Junior Member
Junior Member
Does anyone know why a 3-speed manual 3-on-the-tree transmission would suddenly not engage into gear after three years of trouble free almost daily driving (about three days a week)? Here's what I have. Foot is off the clutch. Car's in Neutral and the engine is idling. Push in the clutch. Slowly move the gear lever either down to first or up to reverse and there it is - the zzzzzzzzz-ing sound of spinning gears just kissing each other. Try to force it and the grinding gets downright ugly.
Sound familiar to anyone?
Chris in North Carolina is :confused:
Spito, spitero, huchtooey splateus!
1958 GMC Series 100 stepside
1954 Chevrolet Bel Air 4-DR sedan
1966 Chrysler Newport 2-DR hardtop
Are you sure that your clutch is dis-engaging ? Check the clutch adjustment...
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
whotmewory,, Welcome to the Stovebolt cool
I think Bill has you covered on this one. Check and adjust the clutch.
One thing,,, with the engine off, can you put the tranny in gear and drive/move the truck in first gear? If it does move in gear, does the truck still try to go with the clutch pedal all the way in?
if so, definitely clutch needs adjustment smile
Junior Member
Junior Member
Thank you Mechainiac and 54 4 me!
It seems the clutch is NOT disengaging. Very patiently, I walked the clutch release fork up and down the linkage rod and through trial and error I have not at all been able to disengage the clutch. Also, With the engine off, and the clutch depressed throughout these trails, whenever I tried to start the engine, the car would lurch forward - still engaged in gear.
So with a lot of research of my mechanic library and original documents and finding no local tranny shops exuding enough confidence :p to tackle a 54 transmission without "strings attached," I am readying myself to remove the tranny from the bell housing and drop the clutch assembly for inspection and rebuild/replace.
Comments? Suggestions?
Check the topic "clutch removal." One other thing I did not add in the other topic. I would recommend draining all the tranny fluid, BEFORE taking anything apart. Trust me. Good luck with it. John.
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI
1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
