6 members (Donf, mo2cyl, Barney1951, Steelonsteel, Stovebolt48, TUTS 59), 78 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#33427 05/20/2005 5:17 AM
Apprentice
Apprentice
Dues anybody make a 8 vo;t regulator
2 elect shops have messed with my reg and still no luck
#33428 05/20/2005 4:38 PM
I don't know anyone who does but I do remember that years ago some of the marine industry was using 8 volt systems. I bought an 8V Delco battery back in the seventies that was marked as Marine use. I had it in a 2 ton GMC 6V system but it wouldn't stay charged and didn't work as well as a new 6V did.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#33429 05/20/2005 9:19 PM
My old Allis Chalmers Tractor ran an 8 volt system.
-Chris
Chris 1955FirstSeries
#33430 05/21/2005 1:55 AM
You should be able to get one at either a mom & pop parts store or an old auto-electric shop.
Are you trying to replace an 8 volt reg, or are you wanting to tune a 6 volt reg higher?
Fred
52 3600
69 C-10
#33431 05/21/2005 2:10 AM
If you're running an 8-volt battery and trying to charge it with a 6-volt generator and regulator, you're doomed to failure. There's simply no way to make it work. The regulator must be adjusted to 9.5 volts, which overloads the generator, burns out headlights and other bulbs, and requires a ballast resistor to keep the ignition from burning out the points. Either go back to a good 6-volt battery, or do the conversion to 12 volts. I grew up around a shop where we did top-quality electrical work in the 50's, and early 60's, and Dad would never attempt to make an 8-volt system work, even when a local battery manufacturer offered to pay him to set up the electrical system for every customer who bought one of their 8-volt batteries. It just can't be done!
