0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#333999 11/07/2007 1:05 AM
Trying to find out what the overdrive ratio is on an original overdrive set-up on a '72 C-10 3-Speed trans.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
I don't know what it is, but here are the usual ranges and general applications (by no means exact or scientific)
0.62 - 0.65 (usually only as a second overdrive "double over") old big trucks and new pickups
0.73 - 0.75 very common automotive and light truck, newer big trucks
0.79 - 0.86 very common big truck
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #334016 11/07/2007 1:45 AM
I'm not sure that GM offered an OD in 72. Not to say that it doesn't have one installed. I beleive the last year was 69 which was a full syncro Saganaw 3 speed trans with a BW OD. The OD ratio for that trans is about .70
Fred
Grigg, Thanks for the info.
Fred, You may be right on that. The only one I ever saw around here was on what I believe was a '69.
.70 would be great.
GMC 9500 Fan
Detroit Diesel Fan
