| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | Happy Days! Does any one have a good way to replace broken/rusted off inside door panel screws? I have 5 that are rusted solid in the door. Tried all of the bug juices I have to no avail. can the old ones be driven out and a new nut tacked in its place? tks, dg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Have you tried heating them? I take a small butane torch with me to the salvage yards just for that purpose. Works great on small screws like the ones in the door panels.
Bill Burmeister | | | | | Joined: Dec 2007 Posts: 4 New Guy | | New Guy Joined: Dec 2007 Posts: 4 | I see you state that not only are your screws rusted, some are broken off. I know they are small, but at this point I personally would get a small bit and try to drill them out. There have been time when doing this, the screws or bolts have actually come loose and began turning. Fortunately I was able to stop in time to be able to then back the screws out. I know it sounds like I have done this many times but I don't want to give that impression. Also, it hasn't worked every time. I was only trying to provide an option. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | As stated above nothing works every time, another option is to use left handed drill bits Dan | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and yes, after you wind up destroying some of the weld nuts, you can replace them - I've used JB Weld, works fine, just dab some on the nut, get it in place on the end of a finger, use vise grips to hold it till cured
Bill | | |
