0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | My 1960 apache, 235 ci, is in a transmission shop. They rebuilt the 3 speed standard about a month ago, but it developed oil leaks so they had to pull it again. The new clutch and pressure plate they installed would occasionally exibit a little chatter when engaging but otherwise worked well. The flywheel was resurfaced when the clutch was replaced. The shop now tells me ( I have not yet been down to inspect it) that the flywheel has some hairline cracks. I have never heard of a flywheel cracking and can find no history of such on the chevy forum. I would have expected the cracks would have been noticed when the flywheel was resurfaced last month. If I have to replace the FW, is a good one difficult to find? Expected cost? What do I need to look for visually to be sure I am looking at the correct FW? meansam | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Flywheels and pressure plates can get hairline heat stress cracks if you are really hard on them (lots of slippage).
I too think it would have been noticed last month before and after it was surfaced. Unless you slip the clutch lots it should not happen in a month. Do you sit at a stop light on a hill holding position with the clutch and not use the brakes?
Unless the cracks were extremely bad, enough to make you think it was unsafe to reuse, I would not expect the minor surface cracks to cause chatter. Sometimes new clutches will chatter some until they have time to seat in. Often this chattering can be avoided by driving / clutching style, and then before you know it, no chatter even if you try.
Lets see some pictures of this flywheel.
Grigg | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Fine surface cracks are alright, as long as the flywheel can still be resurfaced and you just can't find a newer one.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | meansam,
I know this wasn't the the question, but my thought would be to patronize a different transmission shop for any future work.
Stuart | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Or just do the work yourself, as much as you can or want to learn. Getting harder to find pro mechanics with good knowledge and experience of the old iron.
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Many standard transmission flywheels develop surface cracks. They are usually microscopic in size and not a problem. A light surface grinding or machining a slight cut over the surface will correct the condition. Don't worry about it, flywheels on our old 6 cylinder engines are bulletproof, maybe because the engines won't turn enough RPM's to cause any problems. | | |
