1 members (2-Ton), 87 guests, and 5 robots.
Topics128,187
Posts1,057,316
Members48,468
#332928 11/04/2007 5:49 PM
if the front axle from a '36 half-ton is the same as a '53 half-ton?? Thanks
Not the same. King pins and spindles are different but I believe the 47-54 half ton front axles will bolt in as an upgrade.
The axle on the '36 is narrower than the later axles. If you replace the axle you will have the wheels outside of the fenders and will have the tires hitting the fenders. The late kingpins are bigger than the early ones, there used to be available a bushing kit that could be used to adapt late spindles to early axles, but I don't know if they are still available, you could have bushings made to fit.
