1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33339 04/14/2003 2:11 AM | Joined: Jul 2000 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 20 | Although this isn't GM, we were wondering if any of you experts out there can help us. We have a '47 Diamond T model 509 with a Hercules JXC L-head (flat head) engine. When cold and under load, the oil pressure gauge drops to zero. This is not RPM dependent, as it is fine during idle. If pulling a grade when cold and you let off the gas, the pressure goes back to normal. At all other times, the pressure remains 30-40 lbs., which is optimal. Some have told us that this may be worn bearings. What do you think? | | |
#33340 04/14/2003 7:46 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Does it have an electric guage or an actual oil line to the guage? Is there anything interferring with the wires/oil lines from the sender/fitting to the guage :confused:
#33341 04/14/2003 7:35 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Only when cold is the weird part. Are you sure you have the right oil in it?
54 3100 with 235 62 flatbed dump C60 with 261
#33342 04/14/2003 7:39 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | The pickup screen on the oil pump needs cleaning! Every couple months if your usin the truck I bet no one has done this in years on your truck | | |
#33343 04/14/2003 7:58 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That sounds like a good chance. But, are you telling us you drop the pan every couple of months?
#33344 04/14/2003 9:45 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Change your oil every six months if your not driving it or every 1500 miles
Clean the pickup screen every 6000 miles or twice a year.
Water!!!! will also clog the screen....is the oil milky? | | |
#33345 04/14/2003 9:56 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Clean the pick up screen every 6 months? Geez I am years behind on that on every vehicle I ever owned. I once had a Dodge van, the slant six wouldn't pick up oil pressure when it was cold outside The engine had so much blow by, the excessive condensation would freeze on the oil pick up, which was allready pretty sludged up.It finally cured itself when a rod made an unscheduled exit through the block.It was easy to examine the pick up through the hole. | | |
#33346 04/15/2003 1:45 AM | Joined: Jul 2000 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 20 | Thanks for the replies, but please read our question carefully. The oil pressure is fine at idle, but drops when pulling a grade at an RPM that is higher than idle. This does this only when the engine is cold. Therefore, it seems unlikely that it would be the gauge (which has a line to the gauge, not electric). Also, a clogged screen would seem unlikely since the pressure is fine at idle and at running speed as long as the truck is not pulling a grade. But dropping the pan and cleaning the screen might not be a bad idea in any case. The oil, non-detergent 30W, is clear. | | |
#33347 04/15/2003 1:54 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | The only difference between hot and cold is the viscosity of the oil. So, a clog seems like a good guess since when the oil is hot it has no trouble getting through the blockage.
I once had a Chrysler Town and Country station wagon. The transmission ended up doing the same thing when the filters clogged. It would work fine once warmed up.
#33348 04/15/2003 4:13 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Tony this is a Herc not a GM motor.They have a small pump and not much screen area. But I do understand....Anyone that's still using H.D. oil might have some kindda hard time understanding good advice....Bet you believe in Plastigauge and Bonne Ami Seriously you might have a loose or cracked pickup tube but I'd bet it's the screen
If my Diamond T was doing that I'd pull the pan | | |
#33349 04/15/2003 4:56 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Could it be that there is a small portion on the pickup that is NOT clogged, and while going up a grade, the oil does not reach that spot ? | | |
