3 members (Phak1, sparky46, 1 invisible),
133
Mod | | | Forums66 Topics128,168 Posts1,057,025 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33279 04/05/2002 12:03 AM | Joined: Jan 2000 Posts: 51 Member | | Member Joined: Jan 2000 Posts: 51 | i sand blasted some engine tin for the 302 that i'm building and the oil pan has 3 pin holes in it! i would like to repair the pan as it is pretty straight and seems very solid otherwise. any suggestions as far as to how to repair? | | |
#33280 04/05/2002 12:51 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I would take the pan to a radiator shop. They can solder the hole up for you.
if it dosen't need fixed, break it
#33281 04/05/2002 2:29 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | I would not recommend soldering it, I would braze it.
kdot em3
#33282 04/06/2002 1:12 PM | Joined: Jan 2000 Posts: 51 Member | | Member Joined: Jan 2000 Posts: 51 | thanks, i'm going to give it a shot brazing it. | | |
#33283 04/06/2002 9:18 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Just don't burn a hole in it.
#33284 04/07/2002 7:59 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Y'all gotta use either JB Weld or duct tape, don't ya?
Fred 52 3600 69 C-10
#33285 04/07/2002 7:15 PM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | bolt it down to a old block and wireweld in a new bottom if it's that thin
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
