3 members (TexasA&M48Truck, TUTS 59, Stovebolt48), 62 guests, and 8 robots.
Topics128,021
Posts1,055,348
Members48,420
#332549 11/03/2007 7:40 PM
Hey guys! I guess my question is similiar to 49's. I have a 1950 3100 that I plan to use as my daily driver. At the moment, it has a siezed 216 and a 3 speed on the tree. I also plan on taking the truck to the track on the weekends for bracket racing. My initial plan was to run a 350 with 327 heads and a 700R4. I'm not exactly sure that this is going to be able to do what I need it to. Could anyone suggest a good engine/tranny combination? I need to be able to run low 13s.
~Jenny
"Custom can't be bought. It's achieved one cut at a time."
1950 Chevrolet 3100 1/2-Ton
I might be confused but why don't you run a 350 with350 heads?
~Jim
I like a good old set-up of a 350 with a turbo 400 ...just my 2 pennies
1952 Chevy Shortbed
Photos in Photobucket
327 & a 700r4 is what I'm using.
Robert C.
I'm a Genius in the making.
1950 3600
Sorry mobileortho but I'm a little short at the drag strip. I haven't competed at the strip since 1966. Check this site out for an answer or 10: http://www.clubhotrod.com/
~Jim
The only reason I was going to run 327 heads is because I was told that I'd get more out of my engine that way, and because I have them laying around. Unfortunately, I have to use a 700R4 for now, but am planning on putting a 4 speed manual in at a later time and date.
~Jenny
327 heads doesn't really mean a lot. What valves and combustion chambers do these heads have. From a performance standpoint that's what matters.
If your advisor who says you'll get more with the 327 heads knows their stuff it probably means you have some of the better 327 heads. A lot of 350 heads won't be any better and could be worse. On the other hand some of the later 350 heads would be much better.
What compression ratio are you going to run, what intake system and what cam. Those decisions will make a lot of difference.
My 2 cents would be run a set of Vortec heads (off of a late model truck) with the 700R4 and a medium rise intake and about a 600CFM Carb. The Vortec heads add 40Hp easy on a healthy bottom end with the better designed runners, ports, and chambers.
While you have the trans out, pull the case apart, lose the spacer that is with the clutch/discs, and replace with additional clutch/discs. This will prevent you from burning the clutches.
For drag racing, I have done both manual and auto. Auto is the way to go for consistency.
