5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
#332654 11/04/2007 12:10 AM
Does the eagle emblem and base fit over the center piece of my 54 truck or do I need to take or cut out a section of it to apply the eagle... Peter
Petmil/54/3100 #332663 11/04/2007 12:38 AM
Pete,
I assume you are talking about the eagle hood ornament fitting over the divider strip on the hood of your '54. I mounted one on my '54 truck. The base is notched to fit directly over the center divider. No need to cut anything out, but you will need to drill four holes in the hood.
jfjbjr #332667 11/04/2007 12:48 AM
thats great to know thanks for that info
