6 members (tesa, 55shaker, Shade Baby, Gray_Ghost, LAROKE, Wally / Montana), 120 guests, and 2 robots.
Topics128,076
Posts1,055,922
Members48,430
#331356 11/01/2007 2:41 AM
I'm installing a H/W 2bbl on my 250 Chevy. Is the insulator necessary when using the stock manifold, 1 to 2bbl adapter, etc?
I had one on my '54 GMC 248 (don't have it any more). I looked at some pictures I had of it and it looks like I had an insulator on it...check it out...
[IMG]http://i45.photobucket.com/albums/f65/caninelaw/carb4.jpg[/IMG]
Yes, I see it. The insulator I have is with four holes for I suspect, mounting the carb on a 2 bbl. manifold. Perhaps the insulator from the original 1 bbl. Rochester would work where yours was.
You don't remember if you had to, or how you set your electric choke, do you? Mine is not closing completely when cold.
Thanks!
I've run both the Holley/Weber and a pair of Carter/webers on the adaptors on my 235's with no additional insulators and have experienced no problems.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
When I installed my dual Holley Webers, Tom Langdon told me that I did not need the insulators. Like Dave, no problems with just using the gaskets that came with the carbs. You adjust the choke by loosening the three or four screws on the ring around the choke element. Rotate the choke until it is lightly closed to the carb opening when cold. Then warm up your engine allowing the choke to open normally. You may have to do a slight readjust if it doewn't open completely.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Ok, so I got the choke adjusted. Thanks for that. I'm havin gan issue going up hill when I try to accelerate, it feels like it is not getting fuel, but if I back off the pedal a bit, it will still climb and run, just under more load. I'm obviously not a carb expert, so I might need a little help here!
There are two jets on the top of the carb that are both marked 195, and two down in the fuel bowl that are marked 132. any ideas?
Hesitation on acceleration usually means a defective accelerator pump. Did you rebuild the carb?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I bought it from Tom Langdon. I think it was rebuilt prior to that.
I'm going to try to adjust the float tonight and drill out the secondary jet to a 1/16" hole. I only had about a 1/4" of fuel in the bowl when I took it off, which doesn't sound like much.
Hopefully that will help.
Just thought I would let everybody know, that on the advice of Tom Langdon I drilled out the secondary main jet to 1/16" and reset the float. Took the ol boy for a drive, and all is well. It idled and drove better than it ever has!!
Thanks for the help!
